solidworks design thick print
  • Thread starter Thread starter enriazzo99
enriazzo99
Hello, everyone. I presented a problem that I didn't find on the forum.
in the print phase directly from solidworks the different line thicknesses are not printed, while saving as pdf and then printing is all printed correctly.
Can someone explain why?
thanks in advance
hello, everyone. i presented a problem that i didn't find on the forum.
can someone explain why?
thanks in advance
in the print screen there is a "thick line..." button, to be set there. this is a document setting, so each design must be set separately.
in the print screen there is a "thick line..." button, to be set there. This is a document setting, so each design must be set separately.
especially thanks for the answer. If by the line thickness you mean what I attach to the screen, it is already set standard and would be fine if it worked though... Unfortunately it only works by converting to pdf and not printing directly. Can it be a printer problem? Sounds a little weird. I honestly thought more about a solidworks problem.. .
I think the normal thickness set at 0.25 is not good, for example, should be 0.4. Try to inspect it and print it, then see if there's a difference.
