solidworks display problems 2023
  • Thread starter Thread starter skia51
skia51
hello to all
since we updated solidworks to version 2023 s.p.5, we have a visualization problem on also small axis.Screenshot 2024-05-14 144655.webpas seen from the image, part of a larger set, some components are invisible, only the edges are visible, it is a problem present on all the company computers that however have all the same hardware,
we updated video card drivers, nvidia rtx 3050 ti laptop, choosing studio drivers instead of gaming.
Does anyone have the same problem? How did you solve it?
the mode is too defined and without pattern to think of a graphic problem. I think it has changed the display of the components.
Hello Massive
it may be the visualization of the components, but I find nothing in the settings, also often when for example I close the zoom, the details that were not in the graphic area appear as in the image only with the edges, then turning the model or clicking on reconstructs, everything comes back as it should be, but sometimes the models remain as in photo for this I think it is a problem of video card
have you tried to extend the tree with the red circled key in the following image and check that there are no particular settings on the components?
That's what happens. .
video card. winduws periodically updates the so and spys on the drivers that install.
For years now we have workstations of e hp with problems...w10 and w11.
the fact is that if you have enabled advanced graphics in solidworks options it is true that it is faster but from these issues.
make driver attempts and settings.
hello mechanics
So you too with the same problem? in practice there is no solution if not to change video card with a certified?
Well, not so. with certified vga there are smears, sometimes there are writings until closing, but a defect like that never happened to me.
for the uncertified vga... if one has to play us and has to do some training is an account, if you work I do not understand why to buy a potentially problematic object from the beginning.
I'm saying because the certified level enters no longer cost a lot. I didn't look now, but also the iris of intel was certified, at some point better that of a geforce, and you are on a really basic cost of workstations.
hello mechanics
It's not what you're using a 2023 software with a 2024 card...try to contact the assistance maybe they can recommend a compatible driver from the rtx30 series...or try installing the non- notebook version. attempts on attempts when you find the right version to save it because of Mechanical windows try to update it.
ok thanks to all for the advice, unfortunately it is the company that decides what to buy and these laptops were a good choice, I will still make some evidence with different drivers.
thanks again and good work
let us know (I am curious), cmq ok that the company decides what to buy but things are always done with criterion, I do not think that an account needs a powerful laptop or a seller, a visualizer or designer a designer, they all need a different machine. then how come all laptops? If you need to work remotely it was better vpn?
I don't think that he who decided to buy all laptops knows the needs of all:)
one of the problems, from which the same view has arisen to us depends on the option "performance improved graphics".
If you remove it back to the way it was in the back years and you should no longer have the problem.
another thing you can try, keeping the previous active option is activate the anti alias for all scenes, this solves the problem that I often see the desktop under solidworks.
then there are the options on the video card, but there is a tern to the lot.
I have always used the nvidia picture....now I have the a4000 and the like.
in the options video card you have to set maximum performance not to make it go in energy saving, and surely set something else, preferring as gpu always the picture.1716035744705.pngas a basic profile I recommend dassault.
other thing, if you have memories etc activate because on windows 11 works better. If it's not compatible, it makes you do the same, but after reboot you realize it's worse.
Unfortunately windows changes with updates and options set today are no longer good tomorrow.
Lately you pass from slow but you see well fast that you see badly.... .
but it seems that nobody cares so much.... we spend 3000€ and more for workstations but go like a 486.
we have solidworks 2022sp5 but the problems are the same.poi with windows 10 it goes much better than with windows 11 to which however it is necessary to go in the options and set decrease latency in the settings screens and customizations of windows.
Also said gdi in the registry at the most possible to avoid unnecessary crashes.
I have an i9 intel for a few months but with w11 it goes like an i7 xeon....bah
thanks to all for the tips on settings to set, I will try a little these days and see if something improves.
Thanks again
