immaginario
hello to all, I am trying to shape an object that presents a curved edge from me made through loft.
problema: in the area where the curve loft, the section does not remain constant (pass from 1.5mm to about 1mm).
to realize this loft, I designed more sketches that present the same thickness (1.5mm) "legated" between them by a sketch/bord of the object.
This is what I have tried:
1 via single loft
2 breaking the loft into 5 parts
3 through a surface that I then became "thiknen" but trying to combine with the main body I had problems
I attach the first 2 things I have tried, however wishing in the file you can see the 3 solution in the hidden body.
Perhaps the problem lies in my approach to model the object.
every advice will be valuable
View attachment 3D bascula.zip
1 via single loft
