solidworks simulation: help for static analysis.
  • Thread starter Thread starter Vit1
Vit1
Good evening again to all.
I would like to receive help to do a static analysis with solidworks simulation. the reference text is that attached.
As for the design of solid 3d I had no problems, as well as to insert the distributed load of 13.5kn.
I have problems with correctly entering the constraints. in the online guide of solidworks simulation I find mentioned "immobile - fixes only the translations" with which I believe I can characterize the bond in a, however I can not find it in the software. I then used "reference geometry" on the face in a, setting all three translations on 0, but I did not find information on rotations (I don't know if they are actually free and I don't know, in case of need, how to block them).
Can you help me? Thank you.
you can use a fixed geometry bond (simple) and select the face, so there will be no shift or rotation, if you select a edge, you will not have the shift but only the rotation on that edge.
