some specific questions
  • Thread starter Thread starter PLT
PLT
hi, using inventor 2010 recently I have some things to ask related to the cad3d used in the past (unigraphics).
- how do you have the browser that displays only the list of components I have in the axieme without other things (set of components )?
- how do you see if the details you have in the axieme have or not the table already made?
- how do you make all the components of a set that we have hand-made unseen again?? ?
- how do you understand which components are totally bound by those not or partially bound?
Thank you in advance.
p
- I don't understand.
- there is no function that I know, or if you do dx key on the component (in the browser or in the graphic window) and "open drawing" if the table opens you means that there is, although it is not true if the table file has name different from that of the part file or the axieme
- in the browser expand the tab at the top "representations", expand the voice "view", button dx on the name with the tick at the side and "all visible elements"
- there is no particular way, or try in graphic window to drag the components with the mouse and see if it moves, or in the tab of the ribbon bar "view" activates the command "grades of freedom" and see those not bound, but I never used it. . .
for the first question, if you want to see a list only of the components inserted in the axieme but not of the "mode" in which they are inserted, use the distinct components.
for the fourth question, in addition to what said Ilario you can use the function assemble -> productivity -> analysis degrees of freedom, which creates a list of movements that each component can perform, you can also highlight the single component and its gdl in the graphic window by clicking on the name in the list.
