spac - multifoil help
peromm
Good morning to all, present me are peromm, new user of this forum.
I am an electric designer and uttilizzo spac automation.
I have a big problem that I hope some of you have already encountered and solved.
I need to know if there is a possibility to make a dynamic glue copy between different pages of the same multisheet: I'll explain.
with spac for example I am on page 1 of the multifoil. I have to copy any object (written, lines, block..) from page 1 and paste it on page 2. if I cover the object with ctrl-c and then go on page 2 when I go to paste it paste the object with the layer of page 1 and not of the two (naturally..) (the idea program of electrographics instead glued the new object with the active layer and then I found it on page 2). My question is this: I need a command that allows me to copy an object of a determianto layer and paste it with the active layer at that time (the object code on page 1, I move to page 2, paste the page 1 object with the page layer 2).
spac has the copy function between sheets but too turkey and is not what I want,...
I hope someone will help me.. thanks and good holidays to all.
Bye.
What are the individual layers?
I use a system, derived from the old cadelet, which allows me not only to copy to flight one or more objects from one sheet to another of the same multifoil, but also to copy one or more objects on a series of sheets, to move them from one to another and other things like, type to insert one or more blank sheets ih half to a collection. Can you help yourself?
