special layer... .
  • Thread starter Thread starter terzi88
terzi88
I'm working with the new updated version these days (7.5.1.5).
I create a sketch with various entities (e.g. a circle, a square, a line), the last and return in modeling environment.
with edit object display and choosing the curved filter, check the layer 2 line, rim layer 3 and square layer 4.
from the layer setting window all ok, I find my sketch entities on the various layers assigned.
I continue to work and edit the sketch previously created, add a circle, last sketch and return to ambient modeling.
at this point from the layer setting window I realize that I have lost all the layers previously assigned, the entities have returned to layer 1.
I feel the various passages and it always repeats the same way... .
the strange thing is that if I react to the created sketch and intake no modification (win, quota, new entity...), the layers are maintained.
Am I wrong with something or are there any sects to poke? ? ? ?
Sorry if I've stretched but I wanted to explain step by step the operations performed so that you can try anke yourself.....
Andrea
Andrea
You're weird, huh?
really use layers to change the entities of a sketch? ?
If I have to be honest I use them very pokissimo.... it happened to my colleague ke uses them for everything and I simplified the case as described. . .
here from us in fact there is the tendency to use them to keep in order the various entities of each individual file. . .
with version 7.5 you could do? ...groups??(if it works I try to spread the practicality of use). .
Today I try...:smile:
ok...with the groups I can get the desired result.
is it right to work this way or do you have advice?
I tried with my 7.5 (I have the nx7.5.2.4 beta): the operation of the layers is similar to what you described.open an ir.I personally don't use the layers because I'm nervous about remembering the settings.
I use groups (magari appointed) and turn them on/off.
Plus the hid/unhide command can turn on and off all entities in one shot.
