jim78b
I have fixed mail worked on a dwg loading special lines now from laptop open the file and it doesn't make me see why? If I have to give the file to someone?
hi no I just put the file on the pc. but the concern and that if of the fil file to whom it serves then does not see the lines?you need to copy the form files in the laptop (.shx)
if you have created "special lines" with shapes must be present the form files (.shx) used on the pc should open the drawing. if the corresponding file is not present you should see a "bucata" line in correspondence of the missing forms.quote originally written by gp. displays message
you need to copy the form files in the laptop (.shx)hi no I just put the file on the pc. but the concern and that if of the fil file to whom it serves then does not see the lines?
Okay thanks to all I'm careful!careful to set the right autocad paths in which the .lin files and form files are located.
