special name on table description
  • Thread starter Thread starter Login
Login
Good morning.
Is it possible to parameterize the "name" string that I go to set to detail within the table description?
I want to create a relationship that imposes a string that fishes the "name" parameter in the workspace that I will then enter into the table.
then when I go to change the name string, automatically the voice inside the cartilage will follow accordingly.
Good morning, I allow myself to reform your request so as to understand if I did not misunderstand. you have a 3d model that has a name parameter that you would like to see in the chart of its drawing. if it is so enough to write in the note or in the cartilage cell the string &name. will appear the inserted valiant, plus if you double click it allows you to mofy it by changing the value of the 3d model being such a unique value.
what you ask you can safely do, very simple.
as you have just been told you have the opportunity to recall in the mass cartilage at the table any parameter (number or string), simply inserting the string &nomeparameter.
I think it's the best way to get the unique data, inserting them only in the part/axieme and representing them only in the table.
I didn't explain well.
the solution you have proposed the usual use to have unique data as you say.
In this case, I wanted to tie the name directly to the file name as attached.cs203612 - windchill system parameters like ptc_wm_* show values from generic In my case the item is the one attached.
I therefore wanted to create a relationship of the type: description=ptc_wm...., but I cannot find the corresponding ptc_wm parameter.
Now I understand better, but I can't help you.
I remember that in the past I inserted the file name with &model_name
I can't help you. . .
