Pedron Guest Jul 14, 2024 #1 good evening, for an examination of the unit I have to analyze a broken mechanical component, in my case a cylindrical propeller spring. I have some doubts, the break is hard and the lines you see are beach? Thank you. Attachments img.webp 147.9 KB · Views: 22
meccanicamg Guest Jul 14, 2024 #2 Bye. read more quiThank you. the rest, read This is what discussion and compare images.
TETRASTORE Guest Jul 14, 2024 #3 In your case, being an exam, more than getting a direct answer is preferable to draw on the many resources available on the net as you will have to argue the answers you will give. I mention some, where you can find similarities with your case, accompanied by detailed analysis: - coil spring failure analysis reviewed from residual stress, crytal orientation, and texture - premature fracture of high-strength suspension springs caused by corrosion fatigue cracking Last edited: Jul 14, 2024
