damig
Hello everyone, I have to draw and then assemble in product, a pinion and a rack of an old handle.
the fundamental problem is the fact that being of low invoice the mechanism, the teeth will certainly not be to development of evolving and I believe not even to straight teeth as I have seen a little from the manuals, and the minimum number of teeth for not having interference is about 12 on the pinion while I have just 6 on an external diameter of 20mm ... so I don't know how to draw them, and circle them with the rack (to draw also first). Besides the fact that I don't know a pressure angle, and so I wouldn't even be able to draw the tooth flank and so its shape... Do you have ideas in mind?
