spulsory quota
  • Thread starter Thread starter gargiun
gargiun
good morning, I would like to know from you experienced caia v5 users as you quote drills for extruders automatically. In addition to the hole a part of the exhaust (hole with enlarged seat) which varies depending on the height of the figure/close surface. is it possible to insert also the length of the exhaust in the drilling table? always automatic.
I thank you in advance for your advice or comment.
roberto c.
Bye.
I imagine you make molds; I do this:
-in 3d I create an axle (the same as the zero mold) but with the z coinciding with the bottom of the punch (extractor discharge start).
-in 3d I create "parametric" points in the center of the circle where the discharge ends and the precise part begins.
-in the draw I use the command that creates the tabellina automatically (table coordinate odds; that is the last command of the quotation shovel) going to select with a trap the points I created. I then replace instead of "z" the written "prof.="
in this way I find the posizone x and y of every hole and their depth.
attention to 3 aspects:
1st the table does not update with the move (possible) of the points in 3d; you have to do it again
2nd in the properties of the view, to make sure to see and then select the points, you must enable the item "points 3d"; after generating the table you can again uncheck the item.
3° in the tabellina that appears in the command, from the list, you must select the terna you created.
I do so also for the fountain/bazzetti
we waved
