bradipetto
hello to all and good Sunday, I'll put you the problem.
using the default 3d view, and therefore without the help of cameras, I created splits using the cutting panel. as the one attached.
the problem is that now, I should export them to hang them in the tables of the thesis. I used the same procedure that I used for all other processing, i.e. printing tiffs, via pdfcreator; but at the end of the process I have nothing printed. White sheet.
the only thing I could then do is export them as pictures, but the yield is bad compared to the details of the other elaborates that I managed to print in tiff.
one thing I noticed is that creating a table a0 inside revit and trying to drag these views also happens to them the same thing, that is they do not appear on the table, while the other 3d views, those equipped with camera, yes.
I searched on the forum, and it doesn't seem to have found a problem similar to mine, I don't understand why these 3d views are not printed.
