standard export dwg
PSP11
Good morning to all,
in the study where work began to use revit and is now faced with having to define the standards of use of the program.
after defining an encoding for the views it has now passed to analyze the export of the drawings (views and tables) on editable dwg files in autocad, to allow the diffusion of some drawings of the project also to professionals who currently do not use revit or to set almost complete tables to finish in autocad.
the problem arises in the definition phase of export standard in dwg. It is now impossible for years to export in txt the files of the aia and similar standards in order to import the file on excel and proceed to a structured modification and then create a reference txt to be imported in the other drawings. at the moment the only method would be to individually change all individual settings of each category and subcategory to be able to export, when needed, the standards in future projects.
Some of you know where to recover a list of categories and subcategories in Italian to recreate such a txt? I found only old files with the categories of old revits in English and I would need something to apply to the software in Italian.
I hope I explained.
thanks to all those who will contribute!
Palo
:cool:
if I have understood correctly you want to repair layers and line type for export of dwg from revit.
cyclopic work.. .
if it can serve you I attach the files that you are using to create parameters of who uses dwg, but until now nothing is screwed to anyone. .
Tell me if you need it. .
