start off wrong, how to make up?
  • Thread starter Thread starter acco88
acco88
Hello.
I have an urgent problem to solve and I really know how to do it!
I modeled components starting from a star part,ke at work completed it and it is detected wrong.Now I should import all the features from one side to the other as I can do?
Thank you so much!
explain yourself better...it comes to tell you with copy\paste!
What's wrong with the start part?
I should make a total glue copy of all the features of the tree from one side to another. the star part does not correspond to that of the customer.with a normal copy\paste I fail of the internal references of the model (non copy geometry or copy of other parts) it seems strange as what!
but above all. . .
do 2 lines of presentation and give a sensible title to the 3ad??? ? ?
for acco88:
You, like so many others, have gone wrong:
1) to the thread you have to give a title that lets you understand what you are talking about;
2) as you decided to be part of this community by enrolling, it is good to introduce yourself.
3) let us understand what you miss.... the parameters of the start part? ... references or what else?
for mbt: you are right... and not because you are blond or because you are mandilandia :-)
Stars are not retroactive, so if you don't do it right away you have to put them in one by one after.
I hope I've been clear.
This is part of what ozzy had responded to a discussion so I think the solutions are 3:
1.create a new component/assieme with the right startpart and use copy geometry
2.change parameters one by one
3.Remodels
I would charge in the prt the parameters of the right start.prt.it takes 30sec. just export to txt the correct parameters and insert them into the field of relationships.
copy the reports and upload the right config.
