I am a new forum, I would need a hand in playing this statue as I am a neophyte in the use of sw 3d. sure that you will help me greet you and wish you a good day.
I can't believe
from your first message you deserved an answer like what you had
Anyway:
you should indicate with which software you want to make this model
if the sw you use has the option of pulling on incomicient images of la, recalculating with the splines the guide curves then I would pass to the surfaces but one thing is sure, to realize the piece you post you still have a good experience on the 3d
the tutorials that powers you would not help
each sw uses different methodologies, in the end you would look for solutions that do not exist in rh or that you get by taking different paths.
I suggest you follow the tutorials on ytube or on the rhino forum or on the mc neel site
