storage / storage repeated jobs
  • Thread starter Thread starter tanticapelli
tanticapelli
provided that I use solidworks without additional applications (other than the toolbox).
provided that I do not use any more part configurations because they give me problems of updating in some particular cases especially if it is the sheet.
I wondered whether it was possible to store or in some way to store (copy and paste?) a workmanship for example of drilling that is repeated perhaps in different parts of the same together so as not to completely reconstruct the sketches necessary for the total definition of the function.
I wish I could do the same for the extruded cuts.
I hope I've explained
thanks to all
I don't know if it's the right way, but I'd block with the sketch concerned. then if you have to change it on a single detail explode the block and change it as you want
solution 1 you create library files
2 ctrl+c solution and ctrl+v
Hello Masses,
Forgives ignorance, but I don't know how to create a library... to the maximum until now I have created an archive of sections of profiles like "weldment profiles".
Do you have any links to give me or in any case two straights to do this please?
Thank you very much
Hello Masses,
remaining the possibility to "archive" the processing: it seems to me that once applied this processing (transporting from the project library to the interested face) if the modification (for example changing the veil of a quota) from the project library does not update it where I used it:
Is it correct or I miss something?
so many hairs
every now and then you just need to search in the guide (inserted the library function press the ? on the top right or f1) or in google
hi massive, relative to the option you kindly reported "connect to the library part " I would like to confirm if the bond is attributable only when I attribute the processing.
It seems to me that doing it back is no longer possible.
Moreover, it seems to me that, if I have linked the processing to the library part during the attribution to the work piece, acting in the editors attributed I can remove the check: but this last operation seems to be irreversible.
I hope I explained. . .
