[struct]elimitating elements between two nodes
  • Thread starter Thread starter volaff
volaff
hello to all, excuse the question perhaps deficient but I need to delete a beam4 element between two knots (which correspond to two keypoints as I am working with hardkeypoints) after cleaning up the mesh of an area.
the code I wrote is as follows:
finish
/prep7
the area of interest
Aclear, all! I clean up the mesh of the area
!!now the area is cleaned up but I always have the elements that were included between the two knots that are "disappeared" with mesh
ksel,s,kp,5200
ksel,a,kp,,5202!!select the end keypoints of the element
What now? ? ?
how can I do to eliminate the element! ?
thanks to all
metti che i tuoi due keypoints si chiamino kp1 e kp2
ksel,s,,,kp1
ksel,a,,,kp2
nslk,s
esln,s1
southwest, down
Thank you so much stefano, but if I didn't hurt even with lclear I eliminated the element.
I'm trying to do that.
Thank you and soon!
If the element was created directly with the command "e" with lclear you did not eliminate a worthy [Bleep].
not to be polemical, but for every operation you have to do with ansys open a post?
Thanks for the answer.
I tried to erase but I couldn't, so I did the post.
I ask everyone to come.
Good evening!
