lucignolo_one
provided that my experience with finite elements is very reduced, I have been subjected to the problem of evaluating the resistance of a component (which I have not yet been specified but could be a perm feed silos) subjected to different accelerations in the 3 directions (x,y,z) which are to be studied individually and independently one from the other.
In particular, the question I ask you is as follows:
Is it a task that a neophyte with a little commitment can come to solve, or the type of study requires skills that cannot be compensated in the short time I have available (less than a month considering also that I must continue to carry out the work of "routines")?
demand n.2: having used the pro/engineer for a structural calculation on a frame in which it acted on a limited region a force known in order to assess its resistance and deformation. ...can this analysis use pro/e again or do you need a specific software?if you which?
