Hello
how you can model in workbench the beam illustrated in the attached image. from what from the geometry menu you can freely create the three beams like line-body but then how do you impose the constraints between line-body and line-body?
for these things, if I were you, I would use other software, for example, ftool.
which is also more precise*, because it does not approximate the finite elements.
less than large shifts, effects on board, and other amenities neglected by the de saint venant hypothesis.
Thanks for the advice. The program you've given me does its duty. However I would be curious to know how to solve the same problem with ansys workbench.
