study area contact between roller-piste
  • Thread starter Thread starter mambo1988
mambo1988
Good evening, I came across a problem from which I can't come out, I have to study the contact areas between rollers and beams.
I immediately thought of using hertz theory, considering the cylinder-plan case, in which with a simple formula it is possible to find the contact area, the fact is that this theory considers the normal force on the plane that I unfortunately do not know, or better I also have other stresses.
to make you understand I attach a sketchess.webp...... how does the moment take?
not solving the previous problem I thought of using ansys v14 to make a contact simulation between roller and track, (I followed the tutorial I found on the forum http://www.mece.ualberta.ca/tutorials/ansys/at/contact/contact.html), but I block creating 'main menu > preprocessor > modeling > creating > elements > surf / contact > node to surf I think this is due to the fact that the element type I have on ansys v14 is different from the example. Have you ever studied anything like that? ?
If no one answers you no need to do up, one reason will be there!
You are fully right:frown:, I am a neophyte of ansys. Is it possible that no one can help me and made any simulations between two bodies using contact constraints?
if you go among the useful resources there are a couple of great forums (Americans) you could consult
Since you found what you need, you can also write here the solution to the problem.
will help others.
the purpose of a forum is this
