subaxis and parts
  • Thread starter Thread starter Matteopepe21
Matteopepe21
Hello everyone I am new to the forum my name is matteo, I would like some advice please,
today I found myself in a fairly large set with several repeated components, now I pass to questions.
how to change a component of a series (e.g. 10 repeated pieces I want to change one by making a hole),
How do you insert a component of a series into a subaxieme? Don't let me put it in.
Thanks to all I hope to be explained. .
creating a configuration or cutting together without propagating it to the part
if it doesn't work by dragging the series explodes (it would have to be dissociated to me) and then drags it into the subassieme
if it doesn't work by dragging the series explodes (it would have to be dissociated to me) and then drags it into the subassieme[/QUOTE
Se esplodo la serie non perdo gli abbinamenti?
If I explode the series, don't I lose the match?
if you explore details become independent and not bound.
I do not remember if dragging it directly to the level shift; Try it, maybe it works.
in any case save the axieme, try to explode or drag, if it is not okay to close the axieme without saving.
the most obvious thing would be to exclude the component from the series and insert it for its facts in the subaxieme, but if you specifically ask me to move a component from a series the methods are those indicated previously.
tomorrow I try, thank you
I tried to explode the series but lost all the couplings.. I have dozens of sets to explode I can't do all the matings. . .
I even wrote it.
since, rightly, it does not move a component from the series to the subaxieme, the alternatives are:
that already indicated to exclude the component from the series and insert the component into the subaxieme ex novo
suspend the component from the series and insert into the subaxis the component ex novo
