Onda
I would like to know if in solid works 2009 there is a system to consider a coupling under defined (symbol -)such as a pin in a hole or a screw in its headquarters as fully defined.
in proe there is a check that if I remember correctly it is called "allow assumptions" which should be used in these types of couplings.
Is there something similar in solidworks 2009?
wave
wave
