suitable bond
  • Thread starter Thread starter liga76
liga76
hi guys, I have the need for a bolt to enter a socket while remaining free to move in a longitudinal and latitude sense. but still (even smuggles against) within the maximum space of the asola. What constraints do you recommend me to use? Thank you.
I have not seen the model but this is not a problem that solves with constraints of together, but it is a problem that can be solved in contextual mode.
to which it is probably preferable to create links of reference between the various files that carry the data of the screw and the asola
Can't anyone give me a tip?
I would do so, but charamente the position of the paricular must depend, on a given position of the pin.
You can't control the clash between the parts with the alleys of the environment together.
You have to control it with the analysis tools.
If you need to adapt the postion of the asola to the pin you need to operate with the context modeling or the skeleton.
