superato il n, max warning in ansys- /neer...
  • Thread starter Thread starter enrico1979
enrico1979
Hello everyone
How's it going?
I have a problem related to the number of warnings that in a static analysis made in mechanics, and not in the classic is exceeded- beyond 10000-. this because the problem in question
provides over 1000 bodies and 15000 contacts. I don't know if it makes sense but I still want to try it anyway and the solution goes into lock just because of the maximum warnings allowed by the software. on the net I saw that some had the same problem looking for the resolution by introducing a command line " /beer...". Do you have any advice on this?
thanks in advance and good work
if the model is done as you must warnings you see 1 or maybe 2 not + ... then the command you look for does not solve the problem
