superfice con sweep
  • Thread starter Thread starter Half65
Half65
Hi, I need to make this surface bombed by several sides but it's been hours I've been trying and I just can't... Can someone smarter than me help me?
I would say that it is easier to do it with the limit blend (boundary blend) but perhaps also with the variable section sweep (in wildfire 5) selecting two trajectories with the ctrl and defining a section that however in the case represented by you must be a spline.
Bye.
blend limit with 3 sketches, then cuts with solidification, the quickest according to me.
To hell, I had done it first with creo, then I read wildifre 5 and folded on wildfire 3
use the same technique that I used, you don't need to do so many steps, just change the curves of the limit blend.
