superhatch but without cutting
ManuCasa
is it possible to change the superhatch function so that the blocks that fall not entirely inside the contour are not cut but are not placed?
I modified the superhatch command so that with the blocks do not execute xclip. tested only with the blocks!!!!
replace the file I attach to that in the folder:
c:\program files\autodesk\autocad 20xx\express
Maybe save the original in some other folder.
then open the design in which to use it.
if any blocks will be placed beyond the edge put the variable
pickstyle to 0, delete the blocks and then restore the same variable to its original value.
