suppress the series in a parameterized set
  • Thread starter Thread starter mihele
mihele
hello to everyone I'm not very good at inventor, where I work I had to invent everything to perform the assemblies very quickly.
The question I ask is this.
We build tanks with valves where I created a tube (ipart) so with a drop-down module that indicates how many holes I have to have in the tube and a step, this works, so I created a pipe at 3 steps one to 8 steps and to the others again.
this because if I have an alternating 3 equal and 3 different step I am forced to use the two-step parameter.
in the axieme as well as the parameterized tube assemblies in the holes valves one in the first step and others in the next steps.
with the serial command and the axieme parameter I recalled the tube values so if in the serial command indicates the number I automatically gave the valves follow the tube parameter.
the problem is if I have to use a set already done and use it for 2 outputs the parameter works of the tube but in the axieme remains suspended the valve without any data, should be suppressed but also suppress it there are in constraints in short there is a program that suppresses the series that has no value in the parameter eliminating also the constraints?
thanks a little confusion but it is not easy to express yourself.
try to create an iassembly, loading more iparts, you can then manage the suppression of the screws or other
Thanks for answering me, the problem is that I have in the assembling a part (no ipart) the part is parameterized.
If I create an iassembly then I can't have the distinct material.
setting the filters of the separate components on "properties view" (memory vade I don't know if the description is correct)you should get the list parts sol or the elements you see
I hope you've been helped
