g.lopedote
Hello everyone,
I am a new user and I begin by complimenting the quality of the work done on this forum, really exceptional.
hoping not to make mistakes I ask you my doubt.
I'm working on a surface and I'd like to check its quality. Therefore, taking advantage of the means available in the workbenches gsd and freestyle I came across the command "surface curvature analysis" (surgical curvature analysis). In particular, I used the option "flex area" (inflection area) to highlight any unwanted flexes. the surface seems to be rather "clean" if not that, using the curvature analysis to porcupine, they appear flexi.
I read the caia documentation, but I couldn't fully understand the potential of the command "surface curvature analysis", so I ask you a hand on the subject.
in the attached image, there is the surface in question, analyzed with the command "surface curvature analysis" and the option "flex area". in the green area should not be flexibly, but by doing a porcupine analysis, these appear.
I also opted for the command "flex lines" (inflection line) that traces curves obtained by joining the curved points nothing. as shown in figure (second image), there is only one line of flexo on horseback between the blue and the green area (exactly as I expected), but none in the area where the porcupine shows me the flexes.
So the doubt remains, why do I get the flexes with porcupine analysis?
which command allows me to better verify the quality of my surface?
