gp1nick
hi I have a problem in applying the surface finish symbol.
in practice when I finish the drw I go to put the various notes, tolerances and finishes surfaces, but the latter "works" only the first time!
If, for example, after having already made "a lap" to apply the symbol and closed the relative command window, I realize I have to add another finish, I have no chance to do it because although I touch the finishing/sheep/machined/standard1 command and imposed the parameters, the mouse pointer does not show the symbol and in fact I can not apply roughness on any quota...
I hope I explained. .
Does it happen to you, too? Is there a solution? happens to all my colleagues from I create 5 onwards, we have in common the config file, possible is he the culprit?
thanks to all
thanks to all
