surface for points
  • Thread starter Thread starter summer3d
summer3d
hello to all I wanted to know if with I create given a cloud of points it is possible to create a surface that passes through them.
as if I had to draw the morphology of a land of a land having its reliefs.
depends on how many points you have, if you need the optional reverse module (rex).
from the cloud of points generate mesh and on this you can literally lean the surface.
the points are at most about fifty.
the operation you have in mind with the limited points what is it? and how many points to the maximum allow?
Thank you very much.
I did exactly that! blend of curves in the two directions!
..resolved.
Thank you very much::finger:
