surface shape with present radiation
  • Thread starter Thread starter Daniele-san
Daniele-san
Good morning, guys.
I need help,
I should distort the green color surface I indicated with arrow.
as you can see there is a radiation on the back.
how would it be possible to do so if it is possible?
Thank you!
Good morning, guys.
I need help,
Thank you!
that I know you can not, you must first cancel the rounding, apply the reform, then reapply the rounding.
hi maxopus,
already...this solution was planned.. .
I wanted to avoid it because it is an external radius created before the shell.
means that with calm and cold blood recovering from the beginning trying to make less possible damage... .
hi maxopus,
If the model is very complex and the rounding depends a lot ... you can delete it geometrically without deleting the feature. select the rounding surfaces, go to the surface menu (if I remember correctly) and apply the delete command.
I just tried...
is the command I needed... to avoid spending time unnecessarily adapting references and what else.. .
thanks maxopus
there is also a command not to remove the connection and add the shape : model (model) > surfaces (surfaces) > tangent blend to surfaces (blend tangent to surfaces)
or you could use a sweep starting from the base of the fitting and cutting a tiangular section to get the sform
the tangent blending function to surfaces works but is not particularly versatile.
the function to be used is that at the extreme right but does not allow to have a variable radius to the attack of the sform.Cattura.webp
I actually did some tests this morning and in this case tangent blend to surfaces does not work I realize the inclined surface only from the opposite to what is needed
in any case to be able to do the deform without removing the fitting you have to work a little with the surfaces
