surface with reliefs
  • Thread starter Thread starter Simconti
Simconti
hello to all, is it possible with vw modeling a surface like this?
attachment.php
How?
it is possible having a good knowledge of tools for the modeling of the nurbs surfaces
I do.
the procedure that I recommend is to create a rectangle, then use the command creates interpolated surface, create few vertices v and or, double-clicking on the surface shifts the vertices only on a axis by vinclando them from the way bar. then go away see the result. from 2012 it is also possible to raise all vertices or v simultaneously row per row
There are other ways. depends on what you model and what you have as a reference
Thank you so much!
I also tried with rhino and the cage command, but it's a bit of a mess...
