surface...
  • Thread starter Thread starter Manueldesign
Manueldesign
Good morning, guys.
It's more than a week I'm trying to create an unsuccessful surface!
so I ask you have ever made a surface similar to that of the attached image?
I think it is a simple surface, because nn has the classic fitting to do with "b-rail" or "square" in curvatures, but it has the peculiarity of fitting directing cn the edge of the passruota...nn know if I am explained!
How would you proceed to create a surface of that type?
The edge is a plan. make a plan, tremble over a circular crown and you did.
then, the outer edge is one side of the square, you have to draw the other three sides...
I explained to myself as dogs, didn't I?
I attach files. I put in template two surfaces, I used them because putting the central one in tangence with these two, you get the effect of making the edge disappear at the end of the surface itself.
Can you post it in step or iges, please? I can translate everything and more but the .wire just not...:tongue:
in the alias forum, I thought it was a format used.. .
Here is the igs, what was in "template" now I put it on a different layer, because the template does not exist in an igs.
no, I am writing an article, a sort of benchmark among various software including alias. last year I remember that a ple of alias was available but now I can't find it anymore, so I'm asking a bit around colleagues and friends who use it to make some evidence on my behalf... I also took advantage of the forum:wink:
basically I care to see how alias puts down the surfaces;
Well, then ignore my answer.
to the question "how would you proceed to create a surface of that type?" I gave you a generic answer, a advice on the approach to modeling, valid for any software that models surfaces.
the example I posted, moreover, was right to understand what I said, the quality of the result was not the goal. . .
Thank you very much for the tip, I still have to look at the file... I'm packing and then I take a look :d
Here I am sorry for the delay:tongue:
the surfaces of the file in fact nn are wrong, even if until that point I had already arrived!
I'm thinking that I obviously had to make a different kind of request... so:
How would you do the whole side? ? :biggrin:
because the problem is not the little bit above the wheel to be connected with the edge, the problem is at this point to get a flank constituted by surfaces that do not generate discontinuity between them...linked to the edge!nn want me of evil, by side nn I mean that you have to remake all the flank of the lambo; what interests me is from the nose to after the front wheel.. .I don't know until the handle too, obviously excluding all the details like the air outlet and more!
also on the real machine as you can see from the photo, we can notice after the cut of the bumper going cn the look towards the muzzle (only speak it and exclusively of flank, then nn hood) a kind of ribbing that breaks the continuity of the surface and from where, if we want, the style of the bumper!
But if I wanted that point perfectly smooth to the nose?
I didn't understand the question.
You have a surface that comes from the wheel, you want to make us a tangency surface that goes back...draws the edges and sets the tangent, but I think you got here. Then I didn't understand.
in general, however, always tries to distinguish the details from the mother surface. you first make the mother as a huge sheet, then cut out the edges and details.
In this case I would first do all the flank as a mother's surface. then I would cut the molding (but you say you don't want to insert it).
done this, you have to do the piece over the wheel. In what I sent you, do you see that corner of the back? Well, it should be replaced with the forward edge of the flank surface.
we do so that it is better... if not to words nn c you understand nothing:biggrin:
I sketched the curves of the surface; now join them!!!:36_6_10:
It doesn't make me attach it... it says I send the failed file:frown:...xkè? is a wire in a rar file
Somebody help him... I have no idea!
alternatively. . .fulvioromano@tecnonaval.it...but I don't know if it is lawful to post a private address, in such case you remove it as well!
I couldn't work on it before the weekend. .
