sw 2012 problems speed graphics
  • Thread starter Thread starter xxfast
xxfast
Greetings to all.
I have a problem with sw 2012 with regular license, but I did not do the installation.
with 2011 all right, since they put 2012 a slowdown problem in displaying the various functions, during the changes.
practically when I go to open a function to change sketches and stuff varies the software gets impunta for5/10 seconds.
the same happens in another workstation when I display constraints in a set component. all side boundary lines remain lit and there is a hiccup pattern of graphic display.
what can depend on?
Thank you. :36_1_5:
b is as first try to understand that graphics card mounts the pc, then check if they are available for the version of solidwroks that interest you.
but is it a laptop? or do you have a cpu with sandy bridge that has integrated graphics card?
Can't you have a separate PC?
Is it strange that for a pc you can use in technical office do not even put a dedicated graphics card (nvidia fx,quadro or firepro,firegl)?
here in Abruzzo, some people do not understand a...
Well then try to make him understand that now it would be better to add a pci video card... certified for solidworks 2013 if he wants to improve working time.
is the risk that you run with uncertified vga, once they go well, version changes no longer go. How is the highlighted option set? .
