Raffaele09
Good morning to all,
I am doing a project that provides to simplify the entrance of a nail (not a screw) inside a hole.
This nail is equipped with a head larger than the hole (diameter greater than 2 mm), while the body is smaller than 1 mm.
When I start the simulation with a force of just 1 n, the nail disappears, as if the head does not even notice that you must stop when touching the hole wall.
The only solution I found is to put springs between the head and the upper edge of the hole, but it seems to me to "snatch it".
Basically: how do I say that when you meet the hole wall you have to stop?
Thank you all.
Thank you all.
