[sw2008] deletes its functions
  • Thread starter Thread starter railroad
railroad
Hello everyone
I have a problem with the command deletes: when I go to delete a father function, the command window does not allow me to remove the "cancel even all son functions". Is there any option that allows me to choose whether or not to hold child functions? :confused:
I attach image for clarity. Thank you.
Hello everyone
I don't want to say a cabbage, not knowing the model, but I think you cancel an extrusion and son functions, which are the fittings, are erased automatically. other child functions that can be indifferently left obviously there are no other option should be active.
But it seems to me that you cancel an extrusion and the son functions, which are the fittings, are erased automatically. other child functions that can be indifferently left obviously there are no other option should be active.
the model is simple, it is an empty rectangular box, where I cut a side portion with an extrusion (I attach an image as an example).
As you see, the rays running on the cut, are the same ones that are seen on the back of the box. to me it would be convenient to keep the rear rays (catea for example allows me to choose whether to delete or not the child functions).
