sw2015 problems brand custom paper
  • Thread starter Thread starter weldox
weldox
Hello, everyone!
I'm creating a custom cartilage for a friend of mine, but I'm in a kind of bug.
in practice if I use only the external geometry of the coat of arms of his company I have no problem. but he would like to fill the coat of arms.
then I used the dash/filling (checking the "solid" plot) in its color.
I then created the design model (in horizontal a4) and sheet formats.
When I try to change sheet format happens the unexpected... I have some sort of aberration left: remains a second coat of arms more or less in the position of the size of the previous sheet.
to explain better, if I pass from a4 to a3...the a3 cartilage is perfect, but I have half-sheet a duplicate of the coat of arms...more or less where it would be if the sheet was a4.
Do you have any solution or workaround to suggest?
Thank you so much!
I think you have to create different templates of sheets.
one for each format. a0-a1-a2 etc.
and in each one resize the cartilage with its notes.
If I didn't get it wrong. .
No, it's a kiss. I have to find a workaround, try with an image or something like that. .
Okk solved.. .
first I had created a unique block for the whole cart.. .
now instead I used a separate block for the brand and everything is smooth yarn. Enough aberration.
ps: I am sorry for the 3 messages in a row, but I did not understand how to edit.
Thank you again!
