sweep sezione var
  • Thread starter Thread starter blubossa
blubossa
I can't make a variable section sweep....in attachment the part.
unless I'm wrong about the type of command to use. . .
thanks for the suggestions.
bb
In fact you are wrong, you can't select more than 2 curves in a trajectory, you have to separate them otherwise you will never even succeed if you cry in Cyrillic. :-)
I'll get you the right solution.
