swx 2009 theft of extensions
cacciatorino
I just installed swx engineering stimulus package and I see that she thought well to associate the asm extension, daring that they would be my solid edge joint files. He tried to do the same with the dwg but fortunately I stopped him in time!
Now I reassociated the asm files to solid edge (I had to reregister solid edge to get this!), but if I double-click a sldasm file in the file manager of windows, swx no longer leaves' and tells me that the file does not exist.
I assume that if and swx can't coexist on the same pc because the sldasm extension is actually seen by solidworks as a simple asm?
and then why do you insist on launching internet explorer for resources on the internet when my default browser is firefox?
if before double-click apro swx, then it works. :confused:
..eh,
I think it's a problem with "commun" extensions.
if you have noticed swx consider .asm and .sldasm together/equal. when you install it by default if you assign them for yourself, but when from system you go to change the assignment of files you no longer recognize them.
instead if you first open the program the system will assign the file to the first program that finds it open that supports those extensions. . I think:
I think the same thing can happen for the parties with proe since for swx the .prt and .sldprt are practically the same thing.
all this to intuition eh..
Marco:smile:
..eh,
In fact, I also had the same feeling, perhaps more than a problem of the cad, it is a problem of windows that truncates the extensions to the last three letters.
should do as linux that cares about extensions and goes to see the file content to figure out what it is and consequently choose the right program to open it.
Look, it's a problem I've already exposed in the past. It's hateful that I have all the icons of if replaced with those of sw. The fact is that I don't even know how to make eperche don't mess up.
Look, I turned the solid edge execubiile makevercurr.exe that reprises the situation for the files of itself. I don't know if the executable is present only if you do the "multiversion" installation while instead it is not installed if you do the normal one.
eye that on st the makeverrcurr reopens the templates with the default ones, so make a copy before using it.
regarding internet explorer I think it depends on the fact that the development of solidworks is carried out in close collaboration with microsoft. a couple of days ago to a presentation of sw2010 I had asked if would ever be developed a version compatible with linux or mac, but they told me that it will never happen for commercial reasons of close collaboration with microsoft
Obviously!sw leans on windows search that nails me the pc and without that nothing pack&go.mi lament of this just because we at work have a linux server and sw is the only one that has given me problems.
I windows search I uninstalled it immediately, I do not like software that launch seven thousand services at startup and fill you the screen of unsolicited icons (swx me has put three!), but pack and go also works without windows search.
the fact of the linux server worries me a lot because I use it, and if in addition to swx I have to buy windows server I know that I will tell my client that if it suits him solid edge ok, they will send friends as before.
I windows search installed it only the first time (when they put it) and then more and the pack & go works well even without.
volendo si poteva sistemare da windows explorer.
Marco:smile:
I would say that with proe it does not happen because the proe files are not.prt but .prt.n where n corresponds to the rescue number. this number is normally invisible to the user and only the last saved can be seen from proe, but if needed, the previous saves can be repeated.
Turning makevercurr.exe is the fastest solution. I had also tried from the windows file manager but it works partially, in the sense that the association is modified, while the icons remain those of swx.
Bye.
In fact, the linux server is the one that makes the windows search conflict (at least so I was told by the pc slender). which then eventually skips the indexing of files.. .
in fact who has windows search and linux should be massacred of errors like windows search ... and similar balls.
but the pack&go goes and works equally.
instead regarding the opening of all the sw files, it is a problem that go already rubbing. thinks that even who has only sw (as) first you have to open sw then open any of its files.... . : /
I have a nas linux, on which I have all the files of my centralized archive and nothing strange happens. if you explore resources double click on a file opens swx and the file.
Look, I have a nas linux and file indexing is like it wasn't there. Sometimes he does his duty sometimes not.
Obviously it also counts conf or what else...as in all computer things...bo? ? ? ?
and I if even from the desktop I double click, it opens me sw but not the file . :(((
relative to the problem of icons, it seems to have solved by deleting the file "iconcache.db".
windows recreate it at the next start and now it seems all right, *asm file with icon of if and *.sldasm with icon of swx.
