symbol in cartiglio
  • Thread starter Thread starter Ghirarduzzi.G
Ghirarduzzi.G
I immediately press that this new 3d would be like the continuation of other 3d present in the forum regarding the insertion of symbols, logos and amenity various in the carts or in the table in general.
My need would be to put the timbre of the engineering order in the cartiglio.
I followed the canonical procedure to create the object in question as .prt, to make the table, to create the dxf and from there to create the symbol to be inserted in the carts.
after a quick correction (I sang the pens), the result came out but honestly it is not great. I'll get you a picture.
first because the result is slightly blurred (according to me it has the usual discourse to climb/vector) despite the symbol was created in scale 1:1 and then because having had to "fill" all the letters the symbol is very heavy and only the "weight" folder about 2.5 mb. So the final files are even heavier and they create biblical print queues and then they occupy unnecessarily place in the storage disks.
Finally my only problem is to write along a curve the ditions on the edge of the stamp (of course the horizontal writings do not cause me problems). sin that the "long curve neck" function is only in the model sketcher and not in the well-known function of the 2d sketcher.
Does anyone have any suggestions?
Thank you!
I apologize for the prolixity but I wanted to explain well.
I a similar problem solved by inserting the logo in .bmp format in the cartiglio, does not occupy much memory, the original was quickly realized with a specific program for graphics.
I attach an example
I would say your case is quite different from mine.
In my case it is written using a font, the intent would be to use the annotation tool (or who for him) directly in pro/e.
no text to be inserted in the logo is not variable.
It is only a question of reproducing the stamp by placing the text along the edge of the stamp.
In practice now I'm still here. See Annex.
I just have to complete with the missing text. among other things as you notice the stamp in this way is perfectly defined and the weight of the format is only 32.8 kb.
the image you must insert it into a table cell that forms the cartilage and which houses the stamp, while in other cells insert variable parameters, such as: material, code etc.
No, you don't forgive me, but I think you didn't understand my problem because you're telling me things I'm out of topic. or at least so I think.
My need is to reproduce using text tools, annotation, call them as you want, stamp as you see in the attachment to my first post opening this 3d.
As well known, between the image you sent me and the image I refer to, we lack dictions that I can't insert (engines order provided parma - sectors, etc.). and the reason I can't do it depends on the fact that they are not horizontal but circular.
Of course my problem is to put them in.
Sorry, but if in your cartiglio instead of the cartiglio insert a white background image of the stamp does not go well?I did it for a customer and it is the best solution to have excellent graphics of the logo.
When you go print the drw you will see the logo just like the stamp.
I quote completely, is the best solution...:finger:
bb
Code:
Yes, sorry, I took the wrong image, try with this, however the juice does not change, once you create the stamp with the program you want, make an image and insert it in the cartiglio
Now I'm trying, guys.
I just don't have the image, so I have to find a way to create it.
Can someone tell me a program I could create this image with?
ps and once again an eschmotage to overcome something that pro/e does not. but I ask myself: but if you give the possibility to make the text on a curve in the 3d sketcher for what reason do you not have to give me the chance to do it in the 2d?
Maybe you can, but you get crazy.
You could draw the logo in autocad and import it into the format.
otherwise the best solution is the image of the logo.
I usually use autocad for the creation of the logo, then carry in image (it allows me to have an optimal quality) and the amount in the format.
cmq depends on what programs you have available.
both me and the good old dani have already attached the image, it is up to you to see if the print quality is good!
the images you used descended from mine so they are not the maximum.
Now I see a new one.
I put on track the advertising chart of the company. Man, he's gonna have a software to make those peacocks there.
However, the stamp you have made with pro-and doesn't seem so evil, maybe if you change the text's thickness you can improve it.
you can't expect a program born for other things to process images like photoshop or similar.
I mean... It is not that I am very satisfied!
However you are perfectly right when you say that to each his job, but I think that if you were able to write along a curve on one side it was not bad to leave it on the other.
Staff online
