alex64
Hello
Have you ever seen that st no longer visualizes in sketches (classical mode) symbols of geometric relationship?
In practice I have come across this inconvenience, geometric relationships are no longer evident, although they are retained and recognize them, instead of constraints, dots are sometimes black sometimes blue (at least in my case).
in practice you do not know what kind of bond is active on that intersection date of lines, rather if the circle you designed is bound to the center of the plans and so on.
all the options are properly activated, I tried to restart st, set and relocate all the options but nothing.
all this happened without apparent reason and until recently everything worked correctly
....any suggestion kindly?
alessandro
alessandro
