synchronize "quota" attribute with z
  • Thread starter Thread starter lajack
lajack
hello to everyone, I need your help.. .
I have a file where I have points like blocks, in which in the properties of the various points I have x and y correct but the z is 0 on all points.
points blocks appear, however, with the "quota" attribute for each point.
is it possible to transfer the "quota" attribute to the z to have the 3d share on each point?
Unfortunately, since many points in question, I would need an automatic function. . .
thanks to who can help me
Hello, what does normal autocad mean?
Why don't you try to do a search as indicated?
lisp block attribute to elevatedons autocad
then see how many results....
Civil 3d has a command that does this:with autocad you must have a lisp that automates the procedure. if you do a google search with e.g. "lisp block attribute to elevatedon" I'm sure you will find something.. .
thank you again, problem solved, thank you thank you! !
I leave here the link found that solved the problem, if someone else was in my own situation:
not civil 3d I mean...I was looking as suggested in fact, problem solved! I have put the solution above the problem, if someone else is in my own situation
