reggio
Hello everyone, good year.
I have difficulty connecting some cells of a sheet/file of excel with autocad2011, I did some tests that leave me puzzled:
I open the desired excel file and take me into the desired worksheet, select for example from b35 to d39, copy and take off in autocad
Now on excel, cell d39 I add some characters that I expect to find in autocad, but so it is not, it seems not to be synchronized
I try with double click (even triple or quadruple ...) on the table copied in autocad and I see opening another excel sheet that is not the original,
if I now go to d39 and add changes and save this other excel sheet (only save, not save by name) here is that the changes are also reported on autocad (live!), if I then make other changes, now it does not even need to save and the changes are immediately transferred to autocad (yeppi to yeah!) ...
sin that if except the other excel sheet, the original one does not change and does not memorize any changes :frown:
if I change original excel, in autocad nothing changes
If, except for autocad, the connection remains with the other excel sheet
if then, as it serves to me, select another area of excel (original) b20-d22 and take off on autocad, clicking on this new table in autocad, I will open a new copy of the excel sheet, disconnected both from the original and from the other copy mentioned above...
In short, it seems that every time you paste a group of cells on autocad, this is connected with a "fantasm" excel sheet disconnected with the original and with the other ghost sheets, making everything useless ...:frown:
I ask you, is there any way to really connect and sync some excel cells with autocad2011? explain how?
