system mep
  • Thread starter Thread starter Stefano_68
Stefano_68
Good evening,
I'm in the first place and I need to understand something about mep systems.
I have two machines uta01 and uta02, I would like to place the "objects" (diffusers, flexible, channels) depending on their membership, I explain. .
uta02 resumption.
is correct to duplicate in the browser the air system sent 2 times and to call it uta01 sent, uta02 sent and so for the shooting and then to place on what decided?
I have not understood the difference between system classification, system type and system name
As for the uta, where do I check the name, for example uta01, uta02, ...?
I see that this question has been unanswered for almost a year. I hope you read me.
  • system classification is only a name, the name of the first classification of a system. If you have a personalised system, you must begin by duplicating the system called "other" in English. Maybe it's called "other" in Italian. unless you want the new system to be part of one of the existing classifications.
  • system type is the name of the "son" of a system classification.
    • example 1: father: cold domestic water > son: (a system you have duplicated) "domestic cold water 1".
    • example: father: "other"
  • system name is the name of each group of elements that are connected in the edict. This is like the niece of a system classification and a system-type son.
    • esempio 1: acqua fredda domestica > acqua fredda domestica 1 > acqua fredda domestica 1 1
    • example: other > > > > > > > > > > > > > > > > > > > > > > > > > > > < > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >
  • in the system navigator, you can see the hierarchy, and this helps to understand the organization. I used in my response pipe systems, but the same aplication idea for air systems or electricity systems.
