Christian_spinelli
I have a problem: I should insert a table points that indicate the points I use in the model to make a rigid tube, and so far everything right because the hole table function does to my case. the problem arises when I have to use this tube with a welded flange and quote directly the axieme. no longer takes the points of the pipe part in the board table.
you have ever found yourself in this situation:
ah, use creo 2 m100
ah, use creo 2 m100
