tabelle di computo
  • Thread starter Thread starter danix
danix
simple domandina simple... (I hope it is the same answer :-)
under project imposed 3 levels;
under constructions I create the ground floor;
under views I associate the ground floor to create the plant with quotas, rooms, labels and everything else; I also insert a compute table for the rooms: here a defectunder the level column does not report me any name, no result.
It should give me the name of the level that in the case is ground floor but this does not happen.
remember that the rooms are generated on a view file,
if the rooms generate them under a file of construction the error is not there!
Do plot tables only be generated under construction files?
I hope not!
wow! is nobody interested? ... has no one ever had the same dilemma? . . .
cmq. from what I learned is that the rooms are better designed on construction files. . .
