table holes that disappear
  • Thread starter Thread starter Fulvio Romano
Fulvio Romano
Good morning to all,
a colleague passes me a .dwg made in mechanical 11, I open it in autocad 2007 (I want to refrain from comments!) and I do not display the holes tables.
If you leave me easy polemics of the kind that stracaxxo, you lose me a reference, at least tell me with a red rectangle like when the xrefs are lost, otherwise I risk that mold I send in production and I find myself in the office an energy that brand a 32 key, but... how do I solve it? If the table explodes (I want to refrain even here from comments!) I miss the lyrics.
if you just have to send in the press give a pdf.
if you have to work try to see if with a dxf type format, you avoid the indicated losses.
2007? You're in the future.
should be the command: _attexplode, which is part of the autocad express tools command.
verification, hi :)
if it is a block with attributes (which are not the spherical ones :redface:) keyboard test _burst (I just don't remember if in 2007 there was already).
if there is the command, the block is exploded and the attributes are transformed into texts with attribute value.
if it is not a block, but a peculiar object of mechanical, try to see on the autodesk site if there is a special enabler
exporting to dxf works. I'll try the other commands out of curiosity. But on mechanics, because when I open that tabellina doesn't really exist, I know that there is because I saw the press.
I tried to make some experiment and the problem could be that when you open a dwg file containing mechanical elements with autocad these are converted into elements acad-proxy-entity. while if you open a dxf the same elements become fictitious blocks in the sense that you can't handle them as such because they don't appear in the block editor list).
I tried everything with autocad2010, but it could be that 2007 can't handle these acad-proxy-entity therefore sending for Dutch windows the management of the design.
all strictly to conditional
I'll shoot her... :
but sorry burst, the command suggested by crystal, does not work on the blocks and only on the blocks?
to me it seemed that fulvio needed to export data from a table........... of autocad.
or am I wrong and the autocad tables are comparable to the blocks?
Thank you... and hello.
p.s. I don't have the sw underhand to check.
I realized that I lightning the tables just doesn't see them if not exporting the design to dxf and that it still needs to see them and print them on the drawing that opens him.
Mechanical tables are more similar to blocks with attributes, but I think they have within the strings that are associated with external elements (in this case the drilling circles); similar to the attributes in which a value field is inserted, e.g. file address or precisely, x,y,z position of an element
