table - interrupted section --- how to eliminate it
  • Thread starter Thread starter Cla
Cla
hello to everyone, I'm practicing with the solid edges and I'd like to do a broken section. I did it, a little nosey, but it's wrong and now I can't cancel it... can you give me a hand and let me know how it's done?
you must "disactivate", pressing the appropriate button:
1705135581395.webponce you do this, touch one of the two interrupt lines and press the canc key on the PC keyboard.
hi, I managed to remove the section that I had created wrong simply by selecting it and doing canc, now I would like to make it correct, for example I would like to make a partial section to show the hole in image. I created it in the 3d but I can't put it in the 2d... how does it happen??? Thank you.
you have to create an interrupted section of the view in question in 2d: draw the profile of the interrupted section (i.e. the profile of the "spray" that allows you to see the section of the hole) and, as depth, you have to use an orthogonal view to that of the image you post, of course arriving to the center of your hole.
