table of variables
  • Thread starter Thread starter cecespas
cecespas
I've just signed up to everyone, so please the administrators if there were any other discussions like this that erase my address to an existing one I couldn't find.
I come to my problem that I don't think it's very important. then I would like to connect the excel file to the variables in assembly..... I explain better put the case I have my mobile which and of 1000mmx700mmx850h I would like to create a variable length and depth in assembly and then connect it to all the psm files that you have to edit in length and vice versa for the depth with the excel file.
Thank you very much
win:bekle::bekle:
Thank you very much
win:bekle::bekle:
hi, if you do a search on the online help there are just some examples on how to connect the odds to a excel file, search as variables or link spreadsheets. among other things on the folder c:\programs\solid edge ??? ? \custom\bearing there is also an example file on how to create macros with solid edge and make sure they unfold from the xls file.
Thank you very much
win:bekle::bekle:
Meanwhile hello and welcome... then look at these discussions:http://www.cad3d.it/forum1/showthread.php?t=12709&highlight=excel+solid+edgehttp://www.cad3d.it/forum1/showthread.php?t=10167&highlight=excel+solid+edgehttp://www.cad3d.it/forum1/showthread.php?t=9777&highlight=excel+solid+edgehttp://www.cad3d.it/forum1/showthread.php?t=8472&highlight=excel+solid+edgehttp://www.cad3d.it/forum1/showthread.php?t=2740&highlight=excel+solid+edgeI hope I did a good search.
Bye.
thank you so much I will try to do as you said thank you.....ah can I add to skype?
add... if you didn't do it, it's okay, otherwise I check because I changed it, there was still the old one I don't use anymore. Hi.
I didn't do it because it doesn't make me do it....cmq if you changed it, could I have the new one? Thank you very much
